Bean Counter Posted July 26, 2008 Share Posted July 26, 2008 I just came across some original unused Long Eze plans for next to nothing. I was considering a Cozy Mk IV. Question, is a Long Eze any faster to build than a Cozy? Quote Link to comment Share on other sites More sharing options...
TMann Posted July 26, 2008 Share Posted July 26, 2008 There are several areas that are EZ'r. You don't have to jig the sidewalls of the fuselage or build a turtleback jig to mention two. Quote T Mann - Loooong-EZ/20B Infinity R/G Chpts 18 Velocity/RG N951TM Mann's Airplane Factory We add rocket's to everything! 4, 5, 6, 7, 8. 9, 10, 14, 19, 20 Done Link to comment Share on other sites More sharing options...
Waiter Posted July 26, 2008 Share Posted July 26, 2008 I've never built a Cozy IV, But I would guess that is almost a scale factor. The Cozy IV is larger and a little more complex. I would WAG about 10% - 15% more time and cost to build the Cozy IV vs the LongEZ Waiter Quote F16 performance on a Piper Cub budget LongEZ, 160hp, MT CS Prop, Downdraft cooling, Full retract visit: www.iflyez.com Link to comment Share on other sites More sharing options...
michaelj Posted July 26, 2008 Share Posted July 26, 2008 I have built two MkIVs and currently finishing up a LongEZ. The MkIV is easier to build for two major reasons. The instrument panel is huge compared to the Long panel. This means not only more realestate to install widgets but more room behind (forward) of the panel to route wiring, hoses etc. The second factor is at the other end. The LongEZ firewall is so small that it is a challenge to mount all the hardware that needs to be bolted up. I have an 0320 on the LongEZ. It gets a little frustrating at times trying to wedge things in. Both airplanes are well worth the effort you put into them. Quote Link to comment Share on other sites More sharing options...
Big Steve Posted July 26, 2008 Share Posted July 26, 2008 Having built a Longeze and am about 2/3 done with the structure of a Cozy IV I would say that the Longeze is about what Waiter said 15%-20% less work. I really like some of the things that Nat added to the Cozy IV. The Turtle back and Canopy is a whole lot harder than building a Long. There is a lot more jigging in the IV than the Long If somebody would have given me a set of Longeze plans before I started on the Cozy I would have built another Longeze. There are some things about the Cozy that I like a whole lot more than the Longeze. I like the way the main gear is mounted and the way the motor mount attaches to the airframe. Nat spent more time figuring out nice things too like drip rails and wiring helpers. They are different airframes to build so in some ways hard to compare. I plan on building an open ez when I am done with the Cozy I will probably incorporate several cozy features into that build. Build on Steve Quote Steve Harmon Lovin Life in Idaho Cozy IV Plans #1466 N232CZ http://websites.expercraft.com/bigsteve/ Working on Chapter 19,21 Link to comment Share on other sites More sharing options...
Lynn Erickson Posted July 26, 2008 Share Posted July 26, 2008 I just came across some original unused Long Eze plans for next to nothing. I was considering a Cozy Mk IV. Question, is a Long Eze any faster to build than a Cozy? build the airplane thats best suits your wants and needs. there is a lot of time and money in these projects , a lot more then just the cost of the plans. you will be involved with it for a long time during the build but also a very long time when it is done. it is not like a model airplane, if you don't like the one you are building this month you can build a different one next month. most people are lucky to finish one airplane so it is more likely to get finished if it is the one that you really want to own and fly when it is done. Quote Evolultion Eze RG -a two place side by side-200 Knots on 200 HP. A&P / pilot for over 30 years Link to comment Share on other sites More sharing options...
