Ratdog Posted May 23 Share Posted May 23 What are the details on the subject of aluminum verses steel bellcranks on the firewall . My aileron is steel and the rudders aluminum. Quote Link to comment Share on other sites More sharing options...
Kent Ashton Posted May 23 Share Posted May 23 Ask a better question, Lar. Quote -KentCozy IV N13AM-750 hrs, Long-EZ-85 hrs and sold Link to comment Share on other sites More sharing options...
Ratdog Posted May 24 Author Share Posted May 24 I heard that some switched out the aluminum ones in the original plans for steel for concerns of losing control if there was ever a fire in the engine compartment. I cant find any details on this subject in the canard pusher etc. Quote Link to comment Share on other sites More sharing options...
Marc Zeitlin Posted May 24 Share Posted May 24 1 hour ago, Ratdog said: I heard that some switched out the aluminum ones in the original plans for steel for concerns of losing control if there was ever a fire in the engine compartment. I cant find any details on this subject in the canard pusher etc. You need to remember that the aircraft is made of epoxy, which is essentially fuel. So if there's softening or melting aluminum inside the engine compartment, the airplane has long since become a smoldering heap of burned fiberglass and epoxy (and people - at least one) on the ground and the softening of the aluminum belcranks (or anything else aluminum, like the whole bloody engine, or oil lines, or fuel lines) is # 867 on the histogram of things with which to be concerned. The firewall belcranks are steel because they're weldments, and the rudder belcranks are aluminum because they're not. 1 Quote Marc J. Zeitlin Burnside Aerospace marc_zeitlin@alum.mit.edu www.cozybuilders.org copyright © 2024 Link to comment Share on other sites More sharing options...
Ratdog Posted May 24 Author Share Posted May 24 That makes sense thanks Quote Link to comment Share on other sites More sharing options...
