AusEracer Posted October 2 Share Posted October 2 Hi all, Looking for suppliers that can cut the wing and Canard foam. Any suggestions? Also based on what I have read in this forum there is a vast array of foam available. Is that something I would need to specify or would the supplier who makes up the pre-cut kit aware of the specifications? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
zolotiyeruki Posted October 2 Share Posted October 2 What you're looking for is https://eurekacnc.com/ The plans specify which kind of foam to use in various locations. The type of foam is quite important--you don't want to use styrofoam when constructing the fuel strakes, for example. http://www.aryjglantz.com/p/blog-page.html?m=0 <- Ary Glantz has a ton of info on the materials and plans and such. Some of the foams are manufactured in somewhat different thicknesses and/or densities than they were a half century ago, so some adjustments are necessary. Quote Link to comment Share on other sites More sharing options...
AusEracer Posted October 6 Author Share Posted October 6 Thanks Ammon, much appreciated. Quote Link to comment Share on other sites More sharing options...
