Dragonfly Mailing List
1,356 -
Posts posted by Dragonfly Mailing List
Charlie, Fredd, Chris,Thank you for your help; it is much appreciated! Nice video Chris!Regards,MarkVan: main@DragonflyList.groups.io <main@DragonflyList.groups.io> namens Dorothea Keats via groups.io <dkeats@...>
Verzonden: donderdag 21 juli 2022 16:06
Aan: main@DragonflyList.groups.io <main@DragonflyList.groups.io>
Onderwerp: [Extern]:Re: [DragonflyList] Tail wheel lift off speedLET OP: Deze e-mail komt van een afzender buiten Inholland. Wees voorzichtig met het klikken op links en het openen van bijlagen.
ATTENTION: This email is from a sender outside Inholland. Please be careful when opening links or attachments.
Mark---------- As others have said the tail wheel lift depends on
aileron setting and and CG. My airplane likes an aft CG. My tail lifts
about 50 and then I lift off around 70 and keep it in ground effect
until 110 and then climb out.
If you do get it in the air above the runway, do not climb out until
you get some speed.
The elevator is very sensitive so be aware of PIO. When you do get in
the air, do not come back to the runway. Fly around and get used to the
airplane. Nothing worse than trying to land a new airplane five minutes
after your first takeoff.
I usually try to fly around for about an hr before coming back. Be
ready to make another try on landing.
Remember the old expression that any landing you walk away from is a
good one. Any landing where you can reuse the airplane is excellent.
I made a little video years ago explaining how I fly. It may give you
a bit of an idea what to expect.
youtube " Dragonfly Geradlton"
You can check out " Q200 test flight" also. Similar, but faster. Have
fun------------- Chris
This email has been checked for viruses by Avast antivirus software.
https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.avast.com%2Fantivirus&data=05%7C01%7Cmark.ommert%40inholland.nl%7Cc649f368d6214977433108da6b223e1d%7Cad78d191104443038212b6f4dd7874bc%7C0%7C0%7C637940092057692236%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=jWq7oLsC7wgzrWtYCft8qRAAvTCDnQNv6n2PCFHSYRI%3D&reserved=0 -
Thanks for letting me join. I have loved the DF since I first saw the prototype in a magazine. I bought one of the first set of plans after Viking bought the rights to the craft. I have been to most of the flyins when they where in Kansas and Missouri. Life and family has prevented me from building one. (Not complaining at all). Still would love to get started on a project one day.
Let's welcome John Kunz to the group. John pull up a virtual chair and drink of your choice & tell us about yourself
Bill Hidon -
Chris
That’s you in the “Geraldton” videos?!? Those are some of my favorites.
Fredd Baber -
Mark---------- As others have said the tail wheel lift depends on aileron setting and and CG. My airplane likes an aft CG. My tail lifts about 50 and then I lift off around 70 and keep it in ground effect until 110 and then climb out.
If you do get it in the air above the runway, do not climb out until you get some speed.
The elevator is very sensitive so be aware of PIO. When you do get in the air, do not come back to the runway. Fly around and get used to the airplane. Nothing worse than trying to land a new airplane five minutes after your first takeoff.
I usually try to fly around for about an hr before coming back. Be ready to make another try on landing.
Remember the old expression that any landing you walk away from is a good one. Any landing where you can reuse the airplane is excellent.
I made a little video years ago explaining how I fly. It may give you a bit of an idea what to expect.
You can check out " Q200 test flight" also. Similar, but faster. Have fun------------- Chris
https://www.avast.com/antivirus -
I hope to be able to start taxi testing my D-fly in the next 45-50 days. This is good info.
Fredd Baber -
Mark,
Depending on the wing incidence and the ailerons setting. The tail should lift around 45 mph. Hold the stick all the way forward to prevent inadvertently taking off.When you can taxi straight at 35-40 with the tail on the ground the next step is to get the tail up and then slow down and get the tail back on the ground without swerving all over the runway.Practice a lot. You will need good taxi skills right after landing.Regards, -
Dear Dragonflyers,does anyone know at what flight speed the tail wheel gets off the ground during take-off? I am preparing taxi-testing and would like to set initial limitations for low-speed testing.Thank you!Regards,Mark
John Thorp designed some great airplanes, his engineering suits me fine. I borrowed my Dragonfly tailwheel steering modification from my Thorp T18. You are correct Vern, ACS compression spring kit $41.50 or HD identical spring but longer: 2-spring, chain $14.TerryN41521N51079Samsung Galaxy Note 10+
Terry.. These are storm door springs?I like that feature but I have in mind threaded rod with aircraft turnbuckle ends with locknuts.Installed between the Rudder horn and tailwheel attach. Having adjustment ability to add slighttension to the springs.Vern
My method of connecting the tail wheel steering after the rudder horn failure.
Two compression springs.
Terry
N41521
-- Communication ink and paper free
Hi Folks,
I’m looking for some performance data for the Mark II Dragonfly with 100hp at gross weight at sea level. In particular things like:
Takeoff distance -
Climb rate -
Maximum speed in level flight -
Cruise speed at 75% power -
Landing distance -
If anyone has data like that it would be helpful in our project. Along those lines, if anyone has a good number for flat plate drag area for the Dragonfly MK II. That would also be useful.
Thanks
Will -
I'd like to welcome a new member egdorf@...
I just created a folder and uploaded a set of finished contour templates that are courtesy of Charlie Johnson
Give me a call at 513-884-9637 .I’m a Dragonfly owner also.
The zip code is 02891…Westerly RI. Let me know shipping costs and let’s make this happen.
Fredd -
The weight is about 4.5lbs.Where are you located?
Dragonfly Canard GU 25-5(11) 8
Dragonfly Wing. EPPLER 1213 -
Reagarding landing gear, look into the steel gear developed by a fellow builder, Steve Laribee, I think. That's what I have for 700 hrs and some really embarassing landings and the airplane is still reusable.-------------- Chris
That sounds very reasonable. Let me know the weight and how payment can be arranged.
Fredd -
I made a mold directly off of a gear leg in case I may need it in the future. This was of the original MK 11 legs that fitted into sockets in the canard. If required I could measure it up and create a drawing. The layup on my original gear legs looked like a lot of individual rovings in a trough with epoxy. I think that the fibreglass Hoop gear or steel or Aluminium gear legs mounted in the fuselage is a much improved installation . There a many details on these options in past DBFN issues. Many thanks to Bill for uploading the drawings. If all the flying surface airfoils on the Dragonfly had a digital database (inc fin, rudder, elevators & ailerons) and its relationship to the level and waterlines that would be an advantage for new constructors as I understood the drawings were all hand drafted and the Airfoil profiles not identified on the drawings (certainly not on my set). There has been suggestion as to what they were close to .The Mark 11 if I recall correctly had a canard span increase of 12" and each elevator by 17".
Regards,
Bruce -
There never was drawings for the legs. They were purchased items from HAPI.
I have two raw moldings in my possession. They got a bad reputation because builders improperly laminated the bidirectional torsion layers on. N157JG’s legs were destroyed in 10” of re-frozen snow with 900 plus hours of service. I damaged the right leg in 97 time frame but did not know it. The snow finished off the compression side and the remaining fiber snapped in tension.I have obtained additional info on hoop gear geometry but have not looked at it in depth.Regards,Charlie a.k.a. One Sky DogN187JG Mk-II Dragonfly/ 3.0l CorvairMy you tube channel -
I will check the weight-you can have them for 100.00
Re: New Member
in Dragonfly Mailing List (read-only)
Hey John,
View the full article
